2001 Renault Laguna Trouble code p0120
ANDYB1375
Electrical problem
2001 Renault Laguna 4 cyl Two Wheel Drive Manual 115.00 miles
i have trouble code p0120. the car will not rev above 2500 (in limp home mode) i have replace the throttle body and the throttle pedal assembly
Jun 22, 2009 at 12:19 AM
DAVE H
  • 13,383 POSTS
have you had the cars PCM (computer) reset to clear the fault codes and get the vehicle out of limp mode ?
Jun 23, 2009 at 9:42 PM
ANDYB1375
have tryed to clear the codes with my reader but the fault is still present.is there any other way of resetting the ecu?
Jun 24, 2009 at 8:02 AM
DAVE H
  • 13,383 POSTS
You could remove the battery cable (live or earth) for at least 5 minutes ... this should reset the ECU but you will have to perform a relearn drive cycle for the car to relearn all the correct setting's ?? a drive cycle is a 20-30 minute drive in normal everyday conditions (ie.) stop and go traffiic etc. and at least one drive on the motorway for 5/10 mins at 50/60 mph do not do not exceed this speed !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_801.png
Jun 24, 2009 at 10:51 AM
