2001 Renault Laguna Trouble code P0120
ANDYB1375
  • 2001 RENAULT LAGUNA
Electrical problem
2001 Renault Laguna 4 cyl Two Wheel Drive Manual 115.00 miles
i have trouble code p0120. The car will not rev above 2500 (in limp home mode) I have replace the throttle body and the throttle pedal assembly
Monday, June 22nd, 2009 AT 7:19 AM
DAVE H
  • 13,384 POSTS
Have you had the cars PCM (computer) reset to clear the fault codes and get the vehicle out of limp mode?
Wednesday, June 24th, 2009 AT 4:42 AM
ANDYB1375
Have tryed to clear the codes with my reader but the fault is still present. Is there any other way of resetting the ecu?
Wednesday, June 24th, 2009 AT 3:02 PM
DAVE H
  • 13,384 POSTS
You could remove the battery cable (live or earth) for at least 5 minutes ... this should reset the ECU but you will have to perform a relearn drive cycle for the car to relearn all the correct setting's ?? a drive cycle is a 20-30 minute drive in normal everyday conditions (ie.) stop and go traffiic etc. and at least one drive on the motorway for 5/10 mins at 50/60 mph do not do not exceed this speed !!
hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_801.png
Wednesday, June 24th, 2009 AT 5:51 PM
