1999 Renault Laguna serv and transmission lights turned on
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
SOHAILALIKHAN
I gave my renault laguan to a workshop a month ago. After that if I drive my car for a km the serv. and transmission lights are getting turned on. If I continue to drive after another km STOP light is turened on.
Then I stop my car and remove the keys the engine does not stop. It takes around 15 mins. to get it stopped.
Thanks.[img:6243452c8f]http://www.2carpros.com/forum/automotive_pictures/376081_renault_laguna_1999_1.jpg[/img:6243452c8f]
Jun 30, 2009 at 4:34 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated What repairs did the garage do to the car ? you need to have the vehicle plugged into a diagnostic computer to locate the reason these light's are showing ... also is the vehicle KEY or CARD start ? renaults are renowned for electrical faults .. so if the vehicle is card start this fault again should show up on a diagnostic scan ? let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_840.png
Jun 30, 2009 at 10:00 PM
SOHAILALIKHAN
I replaced all engine mountings (the hard rubber that support engine). The garage people removed engine completly to fix the mountings. I dount something might have happen to the automatic transmission. I will take now to the diagnostic center.
Thanks
Jul 1, 2009 at 1:09 AM
DAVE H
  • 13,383 POSTS
sounds like a wiring connector is loose/damaged ...possibly not reconnected correctly during the last repair ?
Jul 1, 2009 at 8:48 PM
