1999 Renault Laguna firing
1999 RENAULT LAGUNA
GARETHW78
Engine Performance problem
1999 Renault Laguna 4 cyl Front Wheel Drive Manual
how do i find out witch cylinder is not firing
Mar 7, 2010 at 6:30 AM
Get an insulated glove remove plug wires one at a time while engine is idling and ground the wire to the engine-A snapping blue spark should be present-
When you remove the wire, the RPM should drop aleast 150rpm if not that cylinder has a problem
Mar 7, 2010 at 6:37 AM
