1999 Renault Laguna cylinder head
1999 RENAULT LAGUNA
PANTHER230763
Engine Mechanical problem
1999 Renault Laguna 4 cyl Front Wheel Drive Manual
does a f4r 2ltr engine and a f4p 1.8ltr engine use the same cylinder heads all the gaskets and torque settings are the same the only difference i can find between the 2 engines is the 1.8 has a 83mm stoke and the 2ltr has a 93mm stoke
Mar 28, 2010 at 8:04 AM
DAVE H
  • 13,384 POSTS
if the heads are form the same year vehicle they should interchange .. i would check for any difference in valve size etc.
Mar 28, 2010 at 8:53 PM
