1999 Renault Laguna
MCKBELL
Transmission problem
1999 Renault Laguna 4 cyl Two Wheel Drive Manual
i have fitted a new gearbox and now the engine will not turn over at all have cheaked the starter moter thats working but when we try to bump start the car stops strait away wont even kick over like normal
May 4, 2009 at 1:49 AM
DAVE H
  • 13,383 POSTS
Does the engine turn over by hand ? .. remove spark plugs and try turning engine over by hand using a spanner/wrench on the crankshaft nut !! was the replacement gearbox new or a used/reconditioned unit ?? let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_643.png
May 4, 2009 at 10:51 AM
MCKBELL
reconditioned unit and it does turn by hand
May 4, 2009 at 6:38 PM
DAVE H
  • 13,383 POSTS
Could you please explain the fault in more detail .. is the car just dead and the starter is not turning over the engine ?? but when you bump the car it dies straight away (does start, but dies) or it will not start at all ?? ...Check the immoboliser is turned OFF .. on some laguna models the Immo' disables starter motor function ... check the wiring to the starter is on correctly and clean off gunk/oil/rust etc. and check main fuse's let me know, as much detail as possible !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_647.png
May 4, 2009 at 10:48 PM
MCKBELL
there is no imobiliser the car turns over but does not start when we bump the car i doesnt even turn over emagine if u treid to bump a car with the ignition off the engine would turn over but not start i dont even get it turning over it just stop the car was fine before i change the gear box (apart from the revers gear was shot) the stater moter kicks in but doesnt stort the car but that is fited/seated correctly
May 5, 2009 at 12:12 AM
DAVE H
  • 13,383 POSTS
There is definately an Immoboliser fitted to a 1999 renault laguna ..it is built into the PCM (cars computer) and is switched off with the keyfob remote for door locks or by turning the key in the lock ... on some models it cut's starter motor function and on some it cut's fuel injection .. you need to check if you are getting spark at plugs and fuel at plug's !! Let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_652.png
May 5, 2009 at 3:49 AM
