1997 Renault Laguna alternator
1997 RENAULT LAGUNA
37,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALFHYDE
How to I slacken and reset the alternator drive belt.
email update:
There is a 7mm allen screw in the centre of the tensioner which has to be slackened off and a nut to adjust it. I am not sure of the size. I could not get a 22mm ring onto it and a 23mm was too big. A 23mm oe spanner turned it.
Jan 20, 2009 at 9:34 PM
MIKE H R
  • 3,094 POSTS
On the engine there is a tension pulley. use a socket and breaker bar to loosen the pulley. Do not take the pulley off but where just take tension off. There should be a diagram under the hood that shows the routuing of the belt. When you put the belt back on you will have to loosen the pulley up again, it is on a internal spring.
Jan 21, 2009 at 1:28 AM
