2002 Renault Espace radio tell tale
2002 RENAULT ESPACE
70,000 MILES • 4 CYL • 2WD • MANUAL
JAI74
hi my problem is that the radio tell tale is reading OFF even though both the radio and cd work and can be controlled by the steering wheel controls the dash just says Off therefore i can't see what station or cd info is doing.i been told this is quite a common problem even though no one seems to be able to offer a solution .thanks for any help you can offer
Mar 30, 2009 at 11:20 PM
DAVE H
  • 13,384 POSTS
you will need to have the radio tested .. i suspect the communication system has a fault inside tha actual radio ! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_415.png
Mar 31, 2009 at 10:34 PM
