1999 Renault Espace clutch problem
60,000 MILES • V8 • 2WD • MANUAL
NOMADIC4460
car isstuck in reverse, clutch cable hasnt broke, gear stick is loose and cant get car out of reverse
Jan 27, 2009 at 6:35 PM
DAVE H
  • 13,383 POSTS
get under the hood/bonnet and try moving the linkages on the top of the gearbox to get the vehicle into neutral .. you have to get the link arm on top of the gearbox in the centre point ..it is trial and error to find neutral .. then check all the likages from gearbox to gearstick ... usually one of them has popped off .. let me know
Jan 28, 2009 at 12:49 AM
