1996 Renault Espace ERG VALVE
44,000 MILES • 4 CYL • FWD • AUTOMATIC
TIGNTUB
Hello
I have had to clean the Erg valve three times at 20k 33k and now at 44k.
The first two times it has been heavily carboned blocking the valves.
I have just noticed a slight deterioration in the performance and decided to check it again.
This time it was covered with quite a lot of what seemed like light oil and sludge.
Any thoughts.
Thanks
Vinny
Mar 3, 2010 at 12:46 AM
MATHIASO
  • 1,209 POSTS
Hello tigntub
Use synthetic oil
Because synthetic oil resists oxidation and viscosity breakdown better than ordinary motor oil, it does not break down or sludge up as fast as ordinary
Use Castrol GTX or Mobile 1.
Change your oil every 3,000 miles or 3 months, whichever comes first
Perform a Seafoam treatment every 18,000 miles, or every 6th oil change. Seafoam is a brand of engine treatment that will push its way through the passages where oil flows. This cleans any sludge out and washes it into the oil pan, where it can be easily drained away. Not only will the Seafoam treatment help fight the battle against oil sludge, but you will probably notice improved gas mileage after using the product
Mar 3, 2010 at 1:39 AM
