1994 Renault Espace fluid in vehicle
IANVERNALL
Interior problem
1994 Renault Espace 4 cyl Two Wheel Drive Manual
I have just noticed that i have a build up of fluid in the drivers foot well. it is not just water as it has an oily feel to it. i have tried to trace the source but i am unable to find it
May 10, 2008 at 8:53 AM
  • 31,937 POSTS
Hi there,
You will have to get the cooling system pressure tested for leak in the heater. if this is not the cause of the leak, check the A/C drain is not blocked. But with an oily feel this may be anti freeze and a leaking heater will be the main concern.
Mark (mhpautos)
May 10, 2008 at 9:18 PM
