1992 Renault Espace alternator ?
140,000 MILES • 4 CYL • 2WD • MANUAL
DAZBAG66
hi wanted to know my espace battery light comes on even though i have changed alternator checked it was working ok before fitted also drive belt fine & tight my battery is new . cant see why it not charging is there a relay or anything else which could be causing this not to charge ,your help much appreciated cheers daz. uk.
Feb 10, 2008 at 7:43 AM
hi
i have a similar problem on a later model. did you find the problem
cheers james
Oct 10, 2008 at 6:09 AM
