1989 Renault Espace fuel.
BROOKLYN12
Engine Mechanical problem
1989 Renault Espace Two Wheel Drive Manual 123,00 miles
my renault espace has a problem with the fuel. when i park it over night the fuel finds it way back and i have a job to start it, when you pump the fuel back through you can see air bubbles in it.
Jan 10, 2010 at 9:04 PM
DAVE H
  • 13,383 POSTS
check for leaks in lines/check pump gasket/check fuel pressure regulator
Jan 11, 2010 at 8:25 PM
