DTC DF998
2014 RENAULT
55,000 MILES • 1.6L • 4 CYL • TURBO • 4WD • MANUAL
EMMBABU
My vehicle gives warning light of CEL with STOP. Below is the DTC
DF998- pressure upstream of turbine Incorrect sensor mounting.
Checked turbo modulator solenoid produces more heat. Is the problem caused this component or what else to check?
Jul 27, 2016 at 6:40 PM
RIVERMIKERAT
  • 6,106 POSTS
The description you give sounds like there is an exhaust leak before the turbo.
Jul 28, 2016 at 4:32 AM
EMMBABU
Other than exhaust leak any other need to check?
Jul 30, 2016 at 11:58 PM
  • 55,781 POSTS
I would check the turbo itself, it could be failing apart inside
Aug 19, 2016 at 2:17 PM
