2008 Renault Clio airbag ecu
9,500 MILES • 4 CYL • 2WD • MANUAL
RAFFLES
airbags and seat belts have deployed,apart from above what else should i change.Is it possible to reset the airbag ecu.And would above stop the engine from starting.The cleo is a 2 door new shape deisel 1-5
May 26, 2010 at 10:17 AM
  • 31,937 POSTS
Hi there, the SRS warning light will go off after all faults with the system are repaired, if you run a scan you will get all the fault codes that will need looking at, i do recommend that any air bag work be done by a qualified tech as it is dangerous work.
Mark (mhpautos)
May 26, 2010 at 10:23 AM
