2006 Renault Clio Clio heater fan
CLIOOWNER
2006 Renault Clio
I've had the same problem as another forum poster with the heater fan speed control works ok at all 4 speed options. When it does work, it works for around 5 minutes or so and then slows down over the course of a minute or so and then stops but more often than not, it doesn't work at all. Tapping the blower casing sometimes gets it to work.
Thanks for any help in the matter!
Jan 27, 2010 at 5:30 AM
DAVE H
  • 13,383 POSTS
I would Replace the blower motor resistor first as this can loose connection when hot .. If this does not cure the fault the blower motor must be breaking down/jamming up when hot !
Jan 27, 2010 at 7:55 PM
