2006 Renault Clio
HOLLYC999
  • 2006 RENAULT CLIO
  • 4 CYL
  • MANUAL
  • 28,000 MILES
My lights will not turn off unless I indicate left and when I indicate right they go on, if I slightly touch the indicator my lights flash. Now my windscreen wipers only work if I pull it a certain way or if I am indicating left? Does this sound like a loose wire?
Thanks
Tuesday, May 4th, 2010 AT 8:07 AM
DAVE H
  • 13,384 POSTS
Sounds like a faulty steering column switch unit ! Replace the switches
Friday, May 7th, 2010 AT 4:10 AM
HOLLYC999
I have warranty, do you think I will be covered for this?
Friday, May 7th, 2010 AT 4:34 AM
DAVE H
  • 13,384 POSTS
This could be covered under a manufacturer's extended warrenty.
Sunday, May 9th, 2010 AT 2:31 AM
