2004 Renault Clio Coughs and splutters when it feels like i
62,000 MILES • 4 CYL • FWD • MANUAL
APPRENTICE1989
it seems to have an over fuling problem as is coughs out black smoke but it only does it sometimes mainly on cold days whether the engine is hot or cold i have changed the coil pack cleaned the plugs cleaned the fule system i know the fule filter has never been changed as you have to remove the petrol tank to change it when it happens the car judders and the power dissapears the more you try and accelerate the worse it gets it only seems to do it bellow 3500 rpm and 70mphand ideas would be greatly appreciated.
Jan 25, 2009 at 11:47 PM
DAVE H
  • 13,383 POSTS
the PCM should be picking up on this fault .. have it read for fault codes !
Jan 28, 2009 at 1:34 AM
