headlights go out
HOTSHOT1811
Electrical problem
2003 Renault Clio
i have been having some strange problems with my Renault Clio regarding the electrics.
It is an intermittent fault where the headlights go out and the indicators, windscreen wipers and the electric windows dont work.
It normally happens within a few minutes of driving off and to fix it i have to pull over and turn the engine off and on again. Sometimes i have to repeat this 3-4 times before it works properly. Occasionally i carry on driving and the lights come back on again but this doesnt happen very often.
Other times i can get in the car and everything works fine 1st time.
Can you suggest anything to help?
Thanks
Apr 1, 2009 at 2:08 AM
DAVE H
  • 13,383 POSTS
It sounds like you have a BCM that is going out because when you reboot the system is starts working like a bad home computer would.
Please let us know what you find.
Cheers
Apr 1, 2009 at 1:25 PM
HOTSHOT1811
Ive taken it to two garages to be looked at, the first said he couldnt locate the fault as it was an intermittent problem. He suggested it might be the wiring in the engine and the second said it may be a problem with the BIC unit but again couldnt be certain because he needed to see the car whilst the fault was there. This is near impossible as i can never tell when its going to happen!!!
He said if it was the BIC unit then it wuld have to go to renault to be fixed!
I hope its not the wiring unit as i had to have that replaced when the car was 18 months old and it was very expensive!!!
Apr 2, 2009 at 9:53 PM
DAVE H
  • 13,383 POSTS
Ufortunately .. the Renault range hase been plagued with electrical faults .. mainly wiring connectors or wires rubbing and stripping insulation .. to try and rectify these faults Renault changed some BCM's (body control modules) this did not work and wiring had to be repaired ... my guess is renault have come across these fault's before and may be your quickest solution to this .. albeit the most expensive .. you could get them to diagnose where the fault lies for you and have it repaired elsewhere !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_428.png
Apr 4, 2009 at 11:27 PM
HOTSHOT1811
It looks like reanult are going to be my last hope then!! Tbh, since i have had it back from the garage it hasnt been anywhere near as bad, i have no idea what they fiddled with but it seems to have worked for now!
I think i will still take it to my local renault dealer just to be safe, thanks for the advice!
Apr 5, 2009 at 7:34 AM
DAVE H
  • 13,383 POSTS
It definately sounds like you have something loose somewhere .. let renault diagnose the fault and have it repaired elsewhere .. please let us know your results ! thanks
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_439.png
Apr 5, 2009 at 10:53 AM
HOTSHOT1811
I just got paid and then took the car down and you where right the BCM has bad it cost me $452.20 to get it fixed. Thanks for you help at least that was free:)
Apr 7, 2009 at 10:13 AM
MEL PETTIPHER
I had the same problem and got a used one out of a car and it worked great FYI saved me because I only paid 50.00 for it.
Jun 7, 2017 at 5:01 PM
CARADIODOC
  • 34,415 POSTS
I can add two comments to the previous conversation. The first is if the head lights are involved with this problem, and they turn off when the ignition switch is turned off, that switch is by far the best suspect. The connector also needs to be inspected for signs of two blackened terminals and / or part of the connector body is melted. If that is found, the switch must be replaced, then the overheated terminals must be cut out of the connector. Those wires will also be hardened from being hot and solder won't adhere to it. About 4" of those wires must be cut off, then new pieces spliced on, then two new crimp-type terminals can be added, but they should be soldered too, then they can be plugged in individually.
As for the dealer being the most expensive place to have this repaired, that is not correct. This will be a new problem seen at most independent repair shops. With no experience, they will have to search for the problem when they can get it to act up, and they will need to consult a wiring diagram. All of that translates into increased time and increased cost. If this really is a common problem, the mechanics at the dealership will be familiar with the car, know exactly where to start looking, and will likely have most of the common solutions memorized. For this type of problem, the dealer is usually the least expensive and most effective at solving it.
Jun 8, 2017 at 8:41 AM
