2003 Renault Clio Renault Clio 1.5 DCi 2003
110,000 MILES • 4 CYL • 2WD • MANUAL
DAVEAIN
Hi, my Clio Diesel sometimes stops/stalls, it's just like someone has turned the ignition key off,.
i can see Air in the low pressure fuel pipes,
fuel going into the pump from the filter looks ok, fuel coming from the pump to the return feed has air bubles in, i have bled the fuel system & primed it twice ??
Mar 2, 2009 at 8:57 PM
DAVE H
  • 13,383 POSTS
you need to discover where/how the air is getting into the system !! check the fuel cap and pump fixings etc.
Mar 2, 2009 at 9:44 PM
