When I turn the key the speedo needle vibrates but nothing else happens?
49,000 MILES • 4 CYL • 2WD • MANUAL
MBIALYJ
im having problems starting my clio sport. when i turn the key the speedo needle vibrates but nothing else happens. it wont even turn over.any ideas what this could be. i also tried jump leads because i thought it could be the batt. but the same thing happend. cheers
Dec 15, 2007 at 11:55 PM
DAVE H
  • 13,383 POSTS
It is a battery fault .. try some better grade jump leads .. or replace the battery ..
Mar 17, 2009 at 3:21 AM
  • 55,616 POSTS
Yep, I agree with DAVE H, this sounds like a battery problem, here is a load test guide for the battery which you can use to confirm the issue.
Please go over this guide and get back to us.
Oct 30, 2024 at 11:16 AM
