Speedometer problem
2001 RENAULT CLIO
MANCONOO
Hi, The needle on my speedometer is working in fits and spurts. The needle will register my speed normally and then it will swing down to 0 km/hr for any number of minutes and then work normally again. Is it a problem with the computer in clock or a loose cable?
Sep 4, 2009 at 7:03 AM
DAVE H
  • 13,384 POSTS
check the wiring to VSS ... and/or replace the VSS (vehicle speed sensor) located on the gearbox housing. Please let us know if you need anything else to get the problem fixed.
Sep 4, 2009 at 10:47 PM
MATHEW12
i have a 2001 clio 1.4 and the cluster is giving me hassels so i would like to know if i can put a second hand one in or is it coded to the car.
the speedo drops to zero while driving and then comes back when it feels like it do know what is the problem
Jul 17, 2019 at 6:58 AM (Merged)
DAVE H
  • 13,384 POSTS
Try checking the wiring to/from or replacing the VSS (vehicle speed sensor) which is located on the gearbox hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_763.png
JAYSONHILL
Hi,I have a problem with my speedo on my Renault Clio.I cant get the speedo to work and i have look all over for info on the sensor or where to find it.Can anyone please help????????
DAVE H
  • 13,384 POSTS
The VSS (vehicle speed sensor) is bolted (by 1 small bolt) to the rear of the gearbox and wires going to it ! your local autoparts store will supply a repair manual with instructions and diagrams
JAMIED741
my lights have blown in the speedo and i cant find out how to get it out PLEASE HELP !!!
DAVE H
  • 13,384 POSTS
we do not have any diagrams for this vehicle .. your local library or autpoarts store will be able to supply a repair manual with step by step instructions and diagrams ... hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_577.png
