2001 Renault Clio right window lifter motor -> one way o
60,000 MILES • 4 CYL • 2WD • MANUAL
GABAOR
to debug, I have unmounted the electric engine from the window lifter mechanic, it works only in one way (UP) and does not work down way
plugged out the motor, and with multimeter I could messaure only 12 volt when pressing windo UP switch, and 0 volt when pressing Down switch
The same situation from the left door's contorl switch.
I have unmounted the right window's control switch, it is working OK.
Does this window lifting has somewhere a relay? controller? Or fuse?
Aug 8, 2010 at 5:25 AM
DAVE H
  • 13,383 POSTS
check the wiring to the switch is good
Aug 14, 2010 at 8:57 PM
