2001 Renault Clio immobiliser
2001 RENAULT CLIO
79,100 MILES • 4 CYL • FWD • MANUAL
LUKE PERRY
my clio will not start and the immobiliser light is flashing on the dash quickly along with the battery and stop light staying on i have dissconnected the key reader and reconnected it and also dissconnected the relays under the bonnet and fitted some off anothe clio and still the car does not start. i dissconnected the 3 connectors under the glove box and left it for 5 minutes and reconnected it. i asked the techs at my work as i work for renault and that is what he told me to do i am an apprentice at renault, a master tech at my work said if its not that it could be the uch?
Apr 23, 2010 at 10:53 PM
DAVE H
  • 13,384 POSTS
The ONLY way to reset your immoboliser system is to plug it into renault's diagnostic computer and have it reset/reprogrammed .. unplugging connectors/sensors/battery will not work .. there is a 4 digit bypass code you can get from renault using your VIN number .. which will temporarily disable the immoboliser and allow you to drive the vehicle ! .. your Master Tech should know this ??
Apr 24, 2010 at 6:20 PM
