2001 Renault Clio humming noise
74,000 MILES • 4 CYL • FWD • MANUAL
PHIL2009
  • 5 POSTS
i have a clio 172 sport, since i had 2 new tyres on the rear they have been catching on the inner arch, the wheels are the manufacturers standard wheel which is a 195/45/r16. what would cause this to happen? it does it on both sides. thanks
Phil.
Jan 28, 2009 at 11:07 PM
DAVE H
  • 13,383 POSTS
have you got lowered suspension ?
Jan 29, 2009 at 1:36 PM
PHIL2009
  • 5 POSTS
[quote:fd9b85d1ce="Dave H"]have you got lowered suspension ?[/quote:fd9b85d1ce] hi, no the whole car is completely standard this is why i have no idea hwat it is as i have never come across this problem . any ideas?
Jan 29, 2009 at 5:06 PM
DAVE H
  • 13,383 POSTS
are they rubbing constantly .. or when you have weight in the back ?
Jan 29, 2009 at 9:17 PM
PHIL2009
  • 5 POSTS
[quote:9bb2b95f91="Dave H"]are they rubbing constantly .. or when you have weight in the back ?[/quote:9bb2b95f91] they are rubbing constantly even when it's just me in the car. it is catching just on the inside corner of the wheel?
Jan 30, 2009 at 2:28 AM
DAVE H
  • 13,383 POSTS
well .. if your not loaded up with boomboxes .. lol .. then either your suspension on both sides has gone faulty at the same time (unlikely) or the tyres must be wrong ? ..
Jan 30, 2009 at 2:33 PM
PHIL2009
  • 5 POSTS
[quote:7cca402fac="Dave H"]well .. if your not loaded up with boomboxes .. lol .. then either your suspension on both sides has gone faulty at the same time (unlikely) or the tyres must be wrong ? ..[/quote:7cca402fac] the tyres are the right size and have checked the suspension and evrything seems to be ok . could you see there been spacers on the rear wheels ? as there arn't any and this would make a bit of sense?
Jan 30, 2009 at 6:25 PM
DAVE H
  • 13,383 POSTS
I will look into the spacer's issue .. but if you have replaced, like for like tyres on standard issue rims and it needed spacers the spacers would already be fitted !!
Jan 30, 2009 at 9:00 PM
PHIL2009
  • 5 POSTS
[quote:8d8fa8dd99="Dave H"]I will look into the spacer's issue .. but if you have replaced, like for like tyres on standard issue rims and it needed spacers the spacers would already be fitted !![/quote:8d8fa8dd99] would that be a posibilty though if they could of come off when the tyres were done , thanks vey much much appreciated : )
Jan 30, 2009 at 10:04 PM
DAVE H
  • 13,383 POSTS
Yes it is possible that the repair shop/garage removed the spacers and didn't replace them as they should ?? and this sounds more likely than both springs/shockers going faulty at the same time !!
Jan 30, 2009 at 10:25 PM
