2000 Renault Clio Car slow in 1st gear
JOEDIB22
Engine Performance problem
2000 Renault Clio Front Wheel Drive Manual 110000 miles
Hi sometimes when i set off in 1st gear my car which is a 1.2 8V alve engine is quite slow, i end up pressing accelerator a bit harder and it soon picks up speed and is fine. It only does this about 30-40% of time out of 100. But i feel abit weary now when driving it. I have recently had time belt replaced as when last fitted it was done wrong and caused all valves and head casket to be damaged. But this problem happened before i had repaire done.
Jan 13, 2010 at 6:59 AM
  • 75,988 POSTS
Sounds like the clutch is slipping, increase of rpm but lacking the pick-up speed
Jan 13, 2010 at 7:02 AM
JOEDIB22
Ahh ok someone else suggested that too. would it not do that in every gear though or will this happen when it gets worse?? Shall i have new clutch fitted now or can it just be adjusted? Thanx for your help
Jan 13, 2010 at 7:21 AM
  • 75,988 POSTS
Try and get the free play and pedal height adjusted and see what happens from there-
Jan 13, 2010 at 7:23 AM
DAVE H
  • 13,383 POSTS
Have the clutch replaced it will gradually get worse and occur in every gear .. it could just fail altogether at a moments notice .. so I would have repaired sooner rather than later ... There is no clutch adjustment possible on this vehicle Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_967.png
Jan 13, 2010 at 12:09 PM
