timing marks diagram is confusing
VIDEOTEKNIX
Engine Mechanical problem
2000 Renault Clio 4 cyl Front Wheel Drive Manual
Could you please send me a copy of the procedure to get my car started for the timing. I have a diagram from Autodata but it points to a timing pin which i dont know where it is located. ive replaced the valves timed it up 3 times cause the cam belt had snapped. And it still wont start :( where have i gone wrong?
my CLIO ll is a 1.2 8v 2000 (w reg) mtv and its been 6 weeks now trying to get it started. I cant afford to take it too a garage and im more than capable to try and tackle it on my own. The car ran (fired) then died straight away :(
please help, I need the car as I have just started full time employment :)
1) yes there is petrol
2) Yes ive checked leads and plugs
3) Yes ive pulled my hair out and chaffed my knuckles.
Guys please help..............TYVM :)
This is what happened,
Head gasket went, replaced and got head skimmed
i put the tension on the wrong side for the cam belt and subsequently my cam belt snapped. I replaced the valves and gasket and belt and timed it back up put it all back together and now i have a fast blinking light in the center of the dash when i try to start it up. It fired then died straight away.
Thinking the worst that i may have snapped the belt again i asked my son to turn the engine whilst i took the oil cap off and checked to see if the rockers are moving. :) to my delight they still moved so the timing belt is still ok. but the car wont bloody start :(
May 9, 2008 at 6:11 PM
  • 31,937 POSTS
Hi there,
In checking my data source, it tells me that vale damage is likely to occur when these belts break. I would be doing a comp test before doing anything else.
Mark (mhpautos)
May 9, 2008 at 6:32 PM
