1999 Renault Clio
KRIS2KN38
  • 1999 RENAULT CLIO
1999 Renault Clio Two Wheel Drive Manual 97000+ miles
My car (1999 1.2L Renault Clio) is making a strange sound more and more frequently over the past few weeks. I had my car serviced a couple of days ago (found various unrelated problems such as - worn front 2 tires, worn front 2 brake pads, leaking back 2 brake wheel cylinders) and they could not find anything that may cause it, they instead told me to let it develop and maybe they could find the cause later down the line. It is a rubbing sort of sound and seems to be coming from the rear of the car, and as various friends have put it; "it does not sound good". I have found that it starts when I press and release the accelerator, but then gets worse to the point where it then makes the noise when I press and release the clutch also. I appreciate any advice. Thanks, Kristen.
Monday, October 26th, 2009 AT 3:13 PM
DAVE H
  • 13,384 POSTS
Have the rear wheel bearings checked !
Tuesday, October 27th, 2009 AT 2:46 AM
KRIS2KN38
Dave, would a problem with the wheel bearings not make a constant noise? Because it doesnt come on until after a few minutes of driving. Regards.
Tuesday, October 27th, 2009 AT 3:03 PM
DAVE H
  • 13,384 POSTS
What sort of noise is it?
Friday, October 30th, 2009 AT 6:34 PM
