1998 Renault Clio doors stuck locked and mileometer and spe
WILKO2507
  • 1998 RENAULT CLIO
Electrical problem
1998 Renault Clio V12
Hi
my clio grande has been playing up the mile counter and speedo are not working and the back doors are stuck in the locked position any ideas what this may be? Also can the door panels be taken off while they're stuck locked if so how
thanks
wilko
Monday, April 6th, 2009 AT 5:20 AM
DAVE H
  • 13,384 POSTS
You need to check or replace the VSS (vehicle speed sensor) located on the gearbox ... you can get the panels off the doors with them closed .. it is a struggle but can be done .. you will need to do this to get the doors open and repair the fault !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_447.png
Monday, April 6th, 2009 AT 10:33 AM
