1997 Renault Clio Wipers, washer and cigarette lighter all
1997 RENAULT CLIO
KEMP_KONG
1997 Renault Clio Two Wheel Drive Manual 57000 miles
Hi
I have a clio and the rear wiper, then window washers (back and front) and the cigarette lighet (for use of the tom tom) have all stopped working.
Is there a simple fix...?
Nov 30, 2008 at 6:03 AM
DAVE H
  • 13,384 POSTS
check the fuses in underdash fuse/relay box .. the list is on the inside cover ?
Dec 5, 2008 at 12:12 PM
RIDEOPA
I had this recently, uve blown the fuse. I put a 20 Amp fuse in place of the 15 Amp and it worked fine after that. The fuses are below the Glove comparmet and i think the fuse you want is over towards the right hand side, its got the pic of the cigarette. hope that helps :)
Dec 30, 2008 at 2:27 AM
SUGGS108
I had this problem too on my 1997 Clio. Found that the fuse indeed had gone and need replacing after consulting the other users comments.
A penny had dropped into to cig lighter and fused it!
Thanks for your help!!
Sorted
Sep 1, 2009 at 7:28 AM
