1996 Renault Clio cooling
87,000 MILES • 4 CYL • FWD • MANUAL
RICHARDDAWSON
hi i have a renult clio 1.4 rt which has been stood for nearly 2 yrs ive changed the oil,filter,coolant, then started it up but the temp went right up and the fan seems real stiff is it the themastat and where abouts is it
Jul 10, 2009 at 6:22 PM
DAVE H
  • 13,383 POSTS
thermostat is located on the engine at the end of the top radiator hose ... replace thermostat and check/flush for blockages in the cooling system also check the water pump is not seized up !!
Jul 14, 2009 at 8:44 PM
