1996 Renault Clio cluth cable
1996 RENAULT CLIO
VALMES
1996 Renault Clio Manual 10060 miles
can i change the clutch cable and how
May 22, 2008 at 3:33 AM
  • 31,937 POSTS
Hi there,
The clutch cable will be replaceable, but unfortunately the data base we have access to dose not include Renaults. But i can only imagine it will be much the same as most other clutch cables. It will have a pin or clip at the top of the clutch pedal, most cables are not bolted to the fire wall, but look just in case, and there will be an adjuster at the clutch end which will need to be backed off to remove that end. I hope that this is a help as i am working blind with this one.
Mark (mhpautos)
May 22, 2008 at 5:28 AM
