1994 Renault Clio CLIO 1.8 16V GEAR SELECTOR
1994 RENAULT CLIO
DELLBOY_
Transmission problem
1994 Renault Clio 4 cyl Two Wheel Drive Manual
HI THERE I HAVE BOUGHT OFF A FRIEND ANOTHER CLIO 16VALVER , ITS THE 1.8 , HE SENT IT TO A GARAGE TO HAVE A CLUTCH FITTED AND FOR THE FOLLOWING 48HRS HAD ALL GEARS , BUT NOW IT HAS 1ST 2ND AND REVERSE , I TRIED TO ADJUST THE LINKAGE TO GET THE GEARS BACK BUT TO NO RESULT :( , I HAVE BEEN TOLD BY MATES IN WORK ETC THAT THESE CARS ONLY HAVE TO BE TURNED A FEW MM TO MAKE A VAST DIFFERENCE IN SELECTING GEARS ? PLEASE HELP I REALLY NEED TO SORT THIS AS OTHERWISE MY NEXT OPTION IS TO CHANGE THE GEARBOX , CHEERS IN ADVANCE :)
Dec 23, 2009 at 9:24 AM
DAVE H
  • 13,384 POSTS
Start by checking all the linkages are connected .. this model has a problem with the connectors popping off .. you may need to replace the linkage connectors !
Dave H
Dec 26, 2009 at 10:41 PM
