1990 Renault 5 Power Steering problem
ELERI1983
Steering problem
1990 Renault 5 Automatic 37950 miles
The power steering on my Renault became very heavy yesterday and was making a very loud creeking noise. I topped up the fluid but this made no difference. When the wheel is fully turned to the left/right its sticks and requires quite al ot of force to get back. Sounds as if the wheel is catching inside the car rather than under the bonnett.
Jun 2, 2009 at 1:00 AM
DAVE H
  • 13,383 POSTS
check/replace the pump if this is working correctly check the actual steering rack for leaks it may just be worn and need replacing !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_766.png
Jun 4, 2009 at 10:50 PM
