Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Avalanche
Drivetrain
Transmission
Replace/Remove
Which way do I turn to remove the transmission converter bolts?
2007 CHEVROLET AVALANCHE
111,111 MILES • 4WD • AUTOMATIC
ALONZOMORANTE6
MEMBER
1 POST
I've been trying for 3 days to remove the bolts from the transmission converter. Which way do I turn to remove the bolts?
Aug 2, 2023 at 10:26 AM
Experienced Mechanic
The torque converter bolts are a standard thread. In other words, they should loosen by turning them counterclockwise. Is that what you are doing?
Aug 2, 2023 at 5:06 PM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
