How do I go about getting the bolt for the crank sensor off?
200,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
THELLELES
I have located the crank sensor for my car listed above, how do I go about getting the bolt for the sensor off? I have heard that I have to go over the oil pan, but it doesn’t seem feasible. Is there a good way to get this bolt off to remove the sensor or do I have to go over the oil pan?
Jan 20, 2024 at 3:05 AM
AL514
  • 5,700 POSTS
Hello, can you take a picture of what you're dealing with? Service info for the 3.5 liter shows the crankshaft position sensor on the back side of the engine, on the side of the engine block, it looks to be under the exhaust manifold. It states to unplug the knock sensor connector first that will help with access to the crank sensor plug. I'll post the diagrams of what service info shows, and if it's different than what you have, let us know. It should be just below the spark plug wires on the back side of the engine.
Jan 20, 2024 at 4:05 AM
AL514
  • 5,700 POSTS
It is on the back of the engine for the 3.5 liter, near the firewall and is easiest to get to from underneath. I would recommend driving the car up on some ramps if possible and blocking the rear wheels for safety. Don't rely on just a jack, always have jack stands under the vehicle as well. The crank sensor is under the exhaust manifold, so you probably won't get to it from up top.
Diagrams 3 and 4 below are the Crank sensor relearn procedure that will need to be done after replacing the sensor.
Jan 20, 2024 at 4:27 AM
