Removing the battery
226 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DANNID1416
I'm trying to access the battery through the wheel well. After i get the tire off what do i do next?
Feb 21, 2021 at 11:19 AM
  • 110,248 POSTS
If I recall, there are plastic push pins and maybe one screw along the fender. Remove enough of them to access the battery. See pic 1. I highlighted where I believe the push pins to be located.
Here are the directions from the manual. They aren't too specific.
__________________________________
2004 Chrysler Concorde V6-3.5L VIN G
Removal and Installation
Vehicle Starting and Charging Battery Service and Repair Removal and Replacement Battery Removal and Installation
REMOVAL AND INSTALLATION
REMOVAL
The battery is accessible without removing the right front wheel and tire assembly.
1. Verify that the ignition switch and all accessories are OFF.
2. Turn the steering wheel to the full right position.
3. Disconnect and isolate the negative battery cable remote terminal from the remote battery post.
WARNING: NEVER GET UNDER A LIFTED VEHICLE IF NOT SUPPORTED PROPERLY ON SAFETY STANDS.
4. Remove the air cleaner housing. Refer to the index for the location of the procedure.
5. Remove battery splash shield. Refer to the Body section of the service for the procedure.
6. Disconnect the heater blanket cord, if equipped.
7. Remove the two short bolts from the battery hold down and remove the hold down.
8. Disconnect the positive battery cable from the battery.
9. Slide the battery toward rear of vehicle.
10. Disconnect the negative battery cable from the battery.
11. Remove battery from vehicle.
INSTALLATION
1. Position the battery in the battery tray.
2. Connect the positive and negative battery cables. Torque to 16 Nm (150 in. lbs.).
3. Connect the heater blanket cord, if equipped.
4. Install the battery hold down and install the hold down bolt. Torque to 16 Nm (150 in. lbs.).
5. Install battery splash shield. Refer to the Body section for the procedure.
6. Install the air cleaner housing.
7. Connect the negative battery cable.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 21, 2021 at 11:38 AM
