Removing seized driver side CV axle
300,000 MILES
RICK FRIESEN
Tried everything to remove axle and it won't budge. is there any trick to it?
Feb 19, 2021 at 4:14 AM
Are you using an axle puller? There are many different types of these but I am sure you will need to use one. The manual has you use a slide hammer which in my opinion works the best.
https://www.2carpros.com/articles/replace-cv-axle
Below is the process from the manual but you can get a slide hammer from most any parts store that has a rental program. Let me know if you can't find one or have questions and we can go from there. Thanks
Feb 19, 2021 at 10:09 AM
