How do you remove rear bench seat?
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BRUNO BARSOUM
  • 28 POSTS
How do you remove rear bench?
On old cars they just popped out.
Sep 5, 2021 at 10:48 PM
SQM
  • 6,383 POSTS
To get the rear seats out you will have to remove few bolts. You will have to pull in a certain way to get the seat cushion out.
I have attached the rear seat removal for both the seat back and seat cushion.
https://www.youtube.com/c/2carpros/featured
Sep 6, 2021 at 3:02 AM
BRUNO BARSOUM
  • 28 POSTS
I am at 7+ days since car was flooded, about foot and a half. Have been drying out inside with towels fans and arm and hammer. Have a dehumidifier on order. Have not tried to start. As previously mentioned battery okay. Dash sites up/windows work. I accidentally discharged battery leaving trunk lid partially opened/light. Battery took charge from overnight charge. I do not think water got into oil. Please see picture of dipstick, if you can tell. Not sure if there are other things to inspect. Waiting for mechanic to stop by to look at starter and anything else? Guy at repair shop thinks I should try to start.
Sep 9, 2021 at 1:43 AM
SQM
  • 6,383 POSTS
The oil seems to be the right color. Just make sure you don't have any water around the air intake area as when you start it can get sucked into the engine. But since it has been over a week any water under hood should have evaporated by now.
If you do not see any water under hood or any obvious sign on corrosion you should be able to start it. Just watch is very closely and listen for any odd noise or warning lights. Shut off immediately if something does not seems right.
Let me know how it turned out.
Sep 9, 2021 at 2:20 AM
BRUNO BARSOUM
  • 28 POSTS
Thanks.
Sep 9, 2021 at 2:27 AM
BRUNO BARSOUM
  • 28 POSTS
There is a plastic cover on intake.Are there clips?
Sep 9, 2021 at 2:28 AM
SQM
  • 6,383 POSTS
As long the filter is dry you should be good.
Sep 9, 2021 at 2:48 AM
BRUNO BARSOUM
  • 28 POSTS
Popped plastic top. Engine Looks normal. No water. Same with air filter, dry.
Sep 9, 2021 at 2:58 AM
BRUNO BARSOUM
  • 28 POSTS
Let me know if you did not get pictures.
Thanks.
Sep 9, 2021 at 2:59 AM
SQM
  • 6,383 POSTS
Got the pictures. It does appear to be dry.
Sep 9, 2021 at 3:40 AM
BRUNO BARSOUM
  • 28 POSTS
Yes. Mechanic has not showed up. So I will try to start Friday and take it in to repair shop.
Is changing all fluids they was to go? And I guess brakes have to be checked.
Sep 9, 2021 at 3:57 AM
BRUNO BARSOUM
  • 28 POSTS
Lastly for today.
Pretty sure I have water in exhaust (2).
My garage entrance ramp is on an incline.
I figure when exiting I will park it on ramp and let it drain for a bit.
Does that sound okay? Repair shop is 2.5 blocks away.
Thanks
Sep 9, 2021 at 4:11 AM
SQM
  • 6,383 POSTS
Unless you have water completely blocking the exhaust you should be able to start is and leaving on an incline should help.
If the engine starts properly and you are on the incline most of the water will come out of the pipe.
Sep 9, 2021 at 4:33 AM
BRUNO BARSOUM
  • 28 POSTS
Got car back from inspection. When started check engine light and air bag lite stayed on. Mechanic came up with a $2,000.00 repair bill. Transaxle I believe and some sensors have to be replaced. Waiting for adjuster next week. Car back in garage with only air bag lite on. He opened floor drain plugs and scanned for engine light and that is off.
Sep 11, 2021 at 1:09 AM
SQM
  • 6,383 POSTS
What was all the damages they find besides the airbag light? Did the water get into transmission?
Sep 11, 2021 at 12:16 PM
BRUNO BARSOUM
  • 28 POSTS
Did not say. Said needs major tune up and I think universal joints? Sensors. Car drives but I parked it of now. Can I tell on transmission dip stick?
Sep 11, 2021 at 11:22 PM
SQM
  • 6,383 POSTS
Anytime you have water damage to a vehicle there could be several item that needs to be replaced.
However they should be only replaced if there is an issue with that given components, not just because you might have gotten water.
See picture below for the transmission dipstick location. The fluid should be checked when the engine is at operating temperature.
Did they give you a written estimate? I am just curious of what they say it will need. Did they actually took a look at the car (put it on a lift or drove it)?
Sep 12, 2021 at 3:04 AM
BRUNO BARSOUM
  • 28 POSTS
I believe it was put on the lift. Probably not driven. He said he pulled out 4 drain plugs under seats, scanned check engine light and that is off now. He came out with a $2,200.00 estimate.(not written) I only go to this guy for emergencies because he is close and I can walk there. Had a recent incident where I hit a pothole that blew left front tire. Bought another tire from him and he said left front shock was leaking and both had to be replaced. His price $900.00. Got it done elsewhere for $400.00.He complained that I took work elsewhere!
Sep 12, 2021 at 3:18 AM
SQM
  • 6,383 POSTS
Only reason I ask about that estimate is you want to be sure the items are getting changed is what needed to be changed, that's. As the car might need all the items that he recommended but you just want to be sure of it. If you dot not have water in the engine or the transmission and you give it enough time to dry. The repair needs might be very minimal.
Sep 12, 2021 at 3:49 AM
BRUNO BARSOUM
  • 28 POSTS
Well, air filter was dry. Could water have entered engine from oil filter? And bottom of transmission? I will take for short drive and check transmission dipstick.
Sep 12, 2021 at 7:48 AM
SQM
  • 6,383 POSTS
If you did not have any leak before, then the water won't have any way to get into the engine thru the oil filter or the drain plug. Same goes for the transmission. Only exception maybe if the engine or transmission was completely submerged for an extended period of time. Other than that water wont enter from the bottom.
Sep 12, 2021 at 7:52 AM
BRUNO BARSOUM
  • 28 POSTS
No fluid on floor before flood. I would say the water was at a height of 1.25 feet according to waterline on wall, and was at that level for several hours before it started to recede.
Sep 12, 2021 at 8:14 AM
SQM
  • 6,383 POSTS
That's good. It was not too high. So basically the bottom of the transmission and the engine got wet.
Sep 12, 2021 at 11:42 AM
BRUNO BARSOUM
  • 28 POSTS
Thanks. On another note. Have the airbag light still on. Is that a major fix?
Sep 12, 2021 at 9:38 PM
SQM
  • 6,383 POSTS
Well, that could be simple as the crush sensor that goes to the bumper or could be a wiring issue or the module. This will have to be scanned for the trouble codes for the air bag to know what might be the issue.
Sep 12, 2021 at 10:55 PM
BRUNO BARSOUM
  • 28 POSTS
Thanks. Have adjuster coming today. So I'll see how things proceed.
Sep 12, 2021 at 11:00 PM
SQM
  • 6,383 POSTS
Well, good luck and let me know how it went.
Sep 12, 2021 at 11:29 PM
BRUNO BARSOUM
  • 28 POSTS
Unfortunately car totaled by adjuster.
Said that flood water had sewage.
Appreciate all the input.
Have recommended site to friends.
Sep 15, 2021 at 10:14 PM
SQM
  • 6,383 POSTS
You are welcome. Thank you for recommending 2CarPros.
Sep 15, 2021 at 11:02 PM
BRUNO BARSOUM
  • 28 POSTS
You are welcome. Any motorcycle mechanics onboard?
Sep 15, 2021 at 11:17 PM
SQM
  • 6,383 POSTS
We do have a very strong team here with very broad experience range.
If you have any questions just open a new thread.
Just go to this link:
Sep 15, 2021 at 11:29 PM
