removing lead to ignition module
200,000 MILES • 3.5L • V6 • AUTOMATIC
MM201297
I am trying to replace my ignition coil the very first thing it says to do is to remove the lead by pressing down and pulling. I can not get this off, no one seems to have seen one like mine and I don't want to break it by doing it wrong.
Feb 7, 2016 at 9:04 AM
MM201297
I've posted a pic of another clip else where on the car. It looks just like this, only the white/gray thing is not there.
Feb 7, 2016 at 9:06 AM
SATURNTECH9
  • 30,868 POSTS
Squeeze the black tab right where the white clip might have been the push it down and pull it up.That's a very common GM car connector.
Feb 7, 2016 at 9:51 AM
MM201297
Thank you, I will definitely try this tomorrow! Thanks again.
Feb 7, 2016 at 10:06 AM
SATURNTECH9
  • 30,868 POSTS
No problem looks like the connector that goes onto the ignition control module that is mounted to your coil assembly.
Feb 7, 2016 at 10:10 AM
MM201297
yeah that would be what it is
Feb 7, 2016 at 12:47 PM
SATURNTECH9
  • 30,868 POSTS
Let me know how it goes.
Feb 8, 2016 at 5:00 AM
