How do i remove the cluster?
174,000 MILES • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
I need to remove the cluster for repairs.
Oct 8, 2021 at 6:33 AM
SQM
  • 6,383 POSTS
To get the cluster out you will first have to remove the trims around the gauge cluster.
Before getting started make sure to disconnect the negative battery cable and wait for at least 90 seconds.
https://youtu.be/_HEC44xENxw
I have attached the replacement instructions below.
Oct 8, 2021 at 7:14 AM
