removing door panel
CLZ3478
I need to remove the drivers side door panel to fix my window on the track which is stuck in the door but, I cant figure out how to remove the door panel since there is only one screw at the top of the panel by the mirror on the interior of the door. Please help??
May 13, 2013 at 4:34 AM
BONEHEADSJ
  • 9 POSTS
Depending on the car and the interrior. There is usually a screw in the handle and if you have an armrest one in there also. You may see a small plastic square covering it. it can can be pried off with a small flat screwdriver. As for the bottom of the door, it's all mostly plastic pop rivets. Pretty much just pull and they come off. Be careful, the break easily. Don't forget the screw by the mirror. Now lift the panel and it should be free of the door, minus any wiring. Then you'll usually find a plastic sheet sealed around the edges with some sticky type rubber. Peel it back and your in. Sounds easy enough. I'v done lots of car stereos. The first time you pull a door panel is always the worst.
May 13, 2013 at 5:12 AM
BONEHEADSJ
  • 9 POSTS
Good luck!
May 13, 2013 at 5:14 AM
Agreed, take your time and remove the screws. the rest is pop pins.
May 13, 2013 at 12:11 PM
