removing and replacing the washer fluid resivoir.
2002 DODGE CARAVAN
180 MILES
NADANE
the lead wire clips been on the van so long I can't get them lose without breaking them, is there some kind of lubricant I can use to get them loose without breaking them?
Jul 26, 2013 at 3:39 AM
CARADIODOC
  • 34,381 POSTS
Try a penetrating oil like WD-40. The Chrysler parts department has something similar called MP-50. You can get other good products at hardware stores and auto parts stores such as PB Blaster. For really stubborn rusted nuts and bolts use Chrysler's "Rust Penetrant". It will do in a few minutes what WD-40 will do in a weekend.
To prevent the plug from being hard to remove next time you can coat the terminals with some dielectric grease. That will prevent them from corroding too.
Jul 26, 2013 at 3:49 AM
