Alternator removal issue
204,000 MILES • V6 • 2WD • AUTOMATIC
VANESSA STRENGTH
Cannot get top bolt out of the old alternator to completely remove it.
Nov 22, 2021 at 8:08 PM
SQM
  • 6,383 POSTS
What issue are you having with that bolt?
Is it seized on the alternator? Or you cannot remove it completely due to it hitting somewhere?
In order to remove the alternator, the right-hand side intermediate shaft needs to be removed along with the splash shield.
https://www.2carpros.com/articles/how-to-replace-an-alternator
I have attached the replacement procedure below.
Nov 23, 2021 at 3:56 AM
