How to remove starter?
150,000 MILES • 4.6L • V8 • 2WD
MARK COSTA
How to pull out starter? can't reach top bolt.
Feb 5, 2021 at 7:50 PM
What tools are you using to try and remove the top bolt? If I remember correctly, you need to use a 24 inch extension and a swivel socket so that you can come at it from a more straight on angle. Then once you get it out, you have to turn the wheels to one side in order to get the starter out.
Here is a video on a mustang. It is not exactly the same but it should give a little different idea.
https://www.youtube.com/watch?v=iySmMQM5OLE
Below is the info out of the manual that doesn't help with the top bolt but is still useful info.
Get a quick video of what you are dealing with if this doesn't help and we can see if there are other ideas. Thanks
Feb 6, 2021 at 9:33 AM
