Remove lower steering shaft?
50,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JTKS40
The shaft has an upper and lower bolt, I was able to remove the lower one but can't break the upper one loose using hand tools. Of course, the upper bolt is beneath the power brake booster, and you can't get a good angle on it, both show to require 40 ft lbs of torque. The lower bolt looked to have blue thread lock on it, do you know if the upper uses red thread lock making it difficult to remove?
Thank you,
James Kennedy
Oct 7, 2024 at 2:30 AM
MECHTRIX
  • 599 POSTS
You need heat to melt and liquify the loctite then it should come off.
Oct 7, 2024 at 3:48 AM
JTKS40
Thank you for your rapid response.
James Kennedy
Oct 7, 2024 at 4:12 AM
  • 55,782 POSTS
Thank you MECHTRIX, have not seen you in a while :)
Oct 10, 2024 at 4:22 AM
