Remove governor
195,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MG STEEL
  • 18 POSTS
Wondering how to remove governor or bypass it or will high performance chip work?
Mar 6, 2020 at 12:03 PM
  • 110,248 POSTS
Are you referring to the rev limiter (I think) or the transmission governor? If it is the rev limiter, that can't be changed or bypassed. It is programmed in to the power-train control module and can't be over written.
As far as a high performance chip, that can be designed to change things like this.
Let me know if that is what you are referring to.
Mar 6, 2020 at 1:40 PM
