Fly wheel nuts removal issue?
8,700,000 MILES
EDGARTV
I'm watching the tutorial you have to remove the Bronco engine; I already have everything ready except for the flywheel nuts. The problem is that the engine is stuck, and I can't rotate it to remove those screws.
What can I do in this case?
Aug 7, 2022 at 2:05 AM
  • 55,770 POSTS
Yep, just pull the engine far forward and the torque converter will come with it, you will loose some transmission fluid so be ready, once the engine is out you can remove the torque converter bolts and then the flywheel.
Aug 8, 2022 at 3:20 AM
