Remove and replace blend door actuator
150,000 MILES
JFGILLIS
I saw a conversation about this and have the problem of air outlet actuator. Clicking sound when mode is on foot area, dash and defrost both work. I have removed the panel beside the gas pedal and see the problem actuator. Wondering what all is involved in removing that part. I see the plug and I believe 3 screws.
Nov 7, 2020 at 1:39 AM
Sounds like you have already done the hard work. You just unplug it and remove the screws and install the new one. Here is a guide that helps with replacing these. Even though this says blend door, the process is the same for any of the actuators.
Let us know what questions you have. Thanks
Nov 7, 2020 at 1:53 AM
