Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Focus
Climate Control
Blend Door Actuator
Replace/Remove
Remove and replace the HVAC blend door actuator instructions needed?
2006 FORD FOCUS
95,926 MILES • 4 CYL • 2WD • AUTOMATIC
WHATAHOOTOWL
MEMBER
1 POST
How do I remove and replace a HVAC blend door actuator?
Aug 23, 2023 at 4:45 AM
Experienced Mechanic
There is only one blend door actuator, (inlet) the others are a manual door control please check out this video and the images below.
https://youtu.be/Kawt1EodtFI?si=dB8RjaFlDS3xGaOr
Images (Click to enlarge)
Aug 24, 2023 at 4:52 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
